| Light source | Rccoer RSD 380W |
| Ballast | Electronic ballast |
| Color temperature | 7500K |
| Lamp life | 1500H |
| Power supply voltage | AC90-240V50/60Hz |
| Machine power | 650W |
| Optical lens | anti-reflective coated glass lens |
| Focus | linear electronic focus |
| Dimming | 0-100% linear adjustment |
| Beam angle | 2.5-52 degrees |
| Characteristic colors | 9 colors + linear CTO + white light |
| Fixed pattern plate | 11 fixed patterns + 1 white light |
| Rotating pattern wheel | 7 glass patterns + white light |
| Effect wheel | fog |
| Prism disk | a 3-sided prism and an 8-sided prism |
| Strobe | 0-20 times/second |
| Motor | Three-phase motor fan with speed control board, which can effectively reduce noise and protect the light source, with integrated folding light hook |
| Control control signal | DMX512 |
| Number of channels | 22CH |
| Control mode | DMX512 control, master/slave mode, self-propelled mode, voice control mode |
| Working temperature | -30 degrees -40 degrees |
| Cooling system | ultra-quiet fan |
| Waterproof grade | IP20 |
| Packaging net weight | 18.8kg |
| Gross weight | 21kg |
| Packing size | 480*410*590mm |
