| Lamp | Roccer 295W |
| Voltage | AC110-240V/50-60Hz |
| Ballast | Electronic ballast |
| Rated Power | 450W |
| Beam Angle | 0-4 ° |
| IP Rating | IP 20 |
| Lens Diameter | 145mm |
| Channel Mode | 18 DMX512 Channel |
| Pan/Tilt | 540/270 degrees,8/16 bit resolution |
| Color Wheel | 14 colors+white, with uv |
| Gobo Wheel | 8 fixed gobos+5 glass gobos+blank |
| Prism | 2 prisms |
| Dimming | 0-100% linear dimming |
| Strobe | 0.5-14 t/s |
| Effects | frost, water-flow, rainbow |
| Product Size | 440x410x540mm |
| Net Weight | 15kg |
| Flight Case size | 730x450x720mm(2in1) |
| Gross weight | 56.8kg(with 2in1 flight case) |
Source
| Lamp | Roccer RSD 295W |
| Lifetime(hrs) | 1500 |
| CRI | 75 |
| Color Temperature(CT) | 8500K |
| Ballast | Electronic |
