LED Wash 19x40W Waterproof with Bee Eye
LED Wash With Bee Eye effect: Each LED lamp bead can be controlled individually, and the fantasy bee-eye dazzle effect comes with focus, dyeing, beam, image, and effect modes. Overheating protection, high-efficiency cooling system, the fan can detect the temperature of the lamp head and automatically adjust the speed.
| Light source | 19 40W RGBW 4in1 Leds |
| Lamp bead life | ≥50,000 hours |
| Total power | 640 watts |
| Input voltage | 100V-240V, 50/60 Hz |
| Focusing angle | 3.5°—50° |
| Control mode | DMX 512/self-propelled/voice controlled/RDM |
| DMX 512 channels | 21/23/35/78/92/97/99 channels |
| Protection level | IP65 |
| Display | 1.8-inch TFT color LCD, 180-degree rotatable, switchable between Chinese and English |
| Power socket | PowerCon input + output |
| Signal input/output | three-core XLR input/output |
| Appearance material | die-cast aluminum |
| Product size | 434*298*530mm |
| Net weight | 22kg |
| Carton packaging | 56*42*64cm Gross weight: 26kg |
| Flight box packaging | 80*49.5*72cm, two in one, gross weight: 74kg |
