LED Wash 19x40W Waterproof
| Light source | 19 40W RGBW four-in-one lamp beads |
| Average lifespan | ≥50,000 hours |
| Input voltage | AC 100V-240V, 50/60HZ |
| Total power | 630W |
| Electronic zoom angle | 3.5°-50°, glass light guide rod + PMMA high-quality optical lens |
| Control | DMX512, self-propelled, master-slave, voice control, manual, RDM |
| Number of channels | 19/27 channels |
| Protection index | IP65 |
| Display | 1.8-inch TFT LCD display, 180-degree rotatable, switchable between Chinese and English |
| Signal input/output | three-core XLR input/output |
| Power socket | PowerCon input/output |
| Appearance material | die-cast aluminum |
| Working temperature | -10℃~45℃ |
| Photoelectric reset system can accurately and automatically correct the X-axis/Y-axis position | |
| Net weight | 22kg |
| Lamp body size | 434*298*530mm |
| Carton packaging | 56*42*64cm, Gross weight: 26kg |
| Flight case packaging | 80*49.5*72cm, two in one, gross weight: 74kg |
Functions and features: gentle mechanical focusing, rainbow effect, circle control effect, large focusing range, wide dyeing area, RGBW color mixing system, full light range dimming; smooth and uniform, low noise and high-efficiency fan cooling system; fast strobe 1 ~25Hz; preset multiple color macro functions; preset multiple effect macro functions.
