Lamp Ignitor Electric Board/Driver/Ballast
Technical Parameter of Power Board Ballast 200W
| Model No | Power | Light Center (mm) | Arc Length | Overall Length | Life Hours | Color temperature | Luminous Flux | Burning position |
| RSD120W 2R | 120W | 46 | 10 | 45 | 6000 | 8000 | 6000 | Any |
| RSD200W 5R | 200W | 51 | 7 | 57.5 | 2000 | 8000 | 10000 | Any |
| RSD230W 7R | 300W | 51 | 7 | 57.5 | 2000 | 8000 | 11200 | Any |
| RSD330W 15R | 330W | 56 | 5 | 58 | 1000 | 7500 | 16000 | Any |
In order to ensure the stability and service life of the light source of the lighting system, the output characteristics of the ballast must precisely match the electrical requirements of the lamps it operates. Therefore, it is necessary to know the lamp type, power, voltage, etc. must be known , to find a ballast compatible with a specific luminaire (lamp).
If you are interested in this product, please be sure to confirm the model of your lamp and the parameters of the bulb. If you have any questions, please communicate with us. Ballast needs to be matched with Lamp.
