Eight Eye Beam Lighting For Concert KTV Party
Products Description
| Product Model | JT-L08R | JT-L08RGB |
| Product Name | Eight Heads Laser Bar Laser Light-8 RED | Eight Heads Laser Bar Laser Light-8 RGB |
| Voltage | AC100V~230V 50~60Hz±10% | AC100V~230V 50~60Hz±10% |
| Power consumption | 100W | 100W |
| With LED | LED 3Wx8,beam angle 5° | LED 3Wx8,beam angle 5° |
| Laser Power | 4W Red (500mW Red Beams*8 pcs) | 4W RGB (500mW RGB Beams*8 pcs) |
| Laser Color | Red Color | RGB full Color |
| Laser system | Motor system | Motor system |
| Laser effects | Laser beams | Laser beams |
| Control mode | sound,automatic,DMX512,master&slave | sound,automatic,DMX512,master&slave |
| DMX channel | 15 CHS | 20CHS |
| Using environment | Indoor | Indoor |
| Application places | KTV,Private rooms and so on | KTV,Private rooms and so on |
| Lighting packaging | Carton packaging,113*33*26CM/2pcs | Carton packaging,113*33*26CM/2pcs |
| Lighting weight | 22KG/2pcs | 22KG/2pcs |
